Disco 2 Auto box no gears
Old Jan 23, 2011 | 04:18 PM
TheoPalvi's Avatar
4th Gear
Unhappy Disco 2 Auto box no gears
I Have a Disco 2 and a strainge thing happened. I was exel to 110klm and kept a constant speed, when I reached town, I slow down to 60 and when I want to keep it at that speed there were no gears. There were no noise or oil under the vehicle. was wondering if someone have had the same problem.
Old Jan 23, 2011 | 07:45 PM
Start by checking the transmission fluid level.
Old Jan 24, 2011 | 03:12 AM
TheoPalvi's Avatar
4th Gear
That was the first thing i did and it's full. Was wondering if it isn't the tourq converter or oil pump
Old Jan 24, 2011 | 07:21 PM
With someone in the drivers seat and you looking under neath when they move the truck do both prop shafts spin?
Old Jan 25, 2011 | 06:23 AM
TheoPalvi's Avatar
4th Gear
the drives shafts didn't turn. I've even check the flex plate behind the torq converter. Donwant to strip out the gbox if it's maybe an electrical problem.
Old Jan 25, 2011 | 07:57 PM
Well the transmission ECU is under the left front seat, pick up a used one and swap it out and see what happens.
I am assuming that your battery and alternator test good.
Low battery voltage will put the transmission computer into "limp" mode, which means 3rd gear only and the "M" and "S" lights will both be on.
The truck will be drivable, but it will take a lot of throttle to get it moving and it will not shift gears.
Old Jan 26, 2011 | 03:36 AM
TheoPalvi's Avatar
4th Gear
thanks spike. I'm going to try it tonight. I'll let you know if it worked?
Old Jan 26, 2011 | 07:45 PM
Please keep us posted.
Mikeggd
Dec 1, 2012 11:55 AM
chazkemp69
Freelander
Dec 4, 2009 04:22 PM
les mitchell
May 14, 2008 12:22 PM
bluehawk
Nov 7, 2007 05:30 PM
ant996
May 29, 2007 11:06 AM
