Disco 2 / Cranks but won't start
Old Feb 2, 2017 | 01:47 PM
gulfdisco's Avatar
The exploding muffler is likely from raw fuel being pumped through the exhaust with out ignition. Then once the ignition came on boom. I don't know how a bad fuel pump could explode the muffler but ive been mistaken before.
Old Feb 2, 2017 | 02:18 PM
zuke's Avatar
If it is backfiring then it is getting fuel and there is power to the pump.
It is getting spark.
Timing?
Old Feb 2, 2017 | 03:14 PM
Luckyjayb's Avatar
Are you using the 18mm spacer for the sensor?
Old Feb 2, 2017 | 03:24 PM
Luckyjayb's Avatar
Old Feb 2, 2017 | 03:27 PM
Luckyjayb's Avatar
Old Feb 2, 2017 | 03:28 PM
shanechevelle's Avatar
If you exploded the muffler, are your plugs wet?
Im a little confused over the exploding muffler too...there would have to be some kind of spark to explode the muffler...along with the fuel.
Old Feb 2, 2017 | 03:30 PM
Luckyjayb's Avatar
[QUOTE=Luckyjayb;594680]
did not know that you are supposed to have the values reset every time you replace the crank position sensor. Anybody else had that issue?
Old Feb 3, 2017 | 03:49 AM
Explorer0863's Avatar
Thanks for the the replies guys. I'm on my way to the mountains for a weekend camping trip. I'll be working on the Disco late Sunday or Monday and report back.
Old Feb 3, 2017 | 06:55 AM
zuke's Avatar
Series Land Rover - Engine Backfires
Whether the engine is petrol or diesel, the common reasons for the engine to backfire in a Series Land Rover are essentially the same. Basically, a backfire is caused when the fuel/air mixture is ignited outside of the combustion chamber. With a misfire, either some of the combustion takes place in the exhaust manifold or in the inlet manifold. Either way there will be a loud bang, and for a diesel engine especially, the neighbours are going to know about it! Backfires most often occur on engine start-up, but the longer it persists then the more serious the problem is and the more damage that can be caused as a result.
Fuel/air mixture causes
A too rich mixture can ignite too early and burn whilst the inlet valve is not completely closed, causing a backfire into the carburettor and air filter. A too weak mixture ignites too late and burns whilst the exhaust valve is starting to open. So the location of the sound effects can give a clue as to nature of the fuel mixture (it may not the real cause of the problem though).
Fuel/air mixtures can be incorrect due to partially blocked air filters (rich mixture); weak fuel pumps or air leaks in the fuel system (weak mixture); a poorly fitting inlet/exhaust manifold can allow air in to weaken the mixture, as can a loose joint in the inlet manifold; in petrol engines, carburettor faults can cause either rich or weak mixtures.
Valve timing causes
If valves open or close at the wrong times then ignition occurs in the wrong places. Cause of faulty valve timing can be incorrectly set valve clearances (will hear a clattering sound from the rocker cover where the valve settings are wrong). Other causes are worn or damaged valve springs or a worn timing chain. If the timing chain is badly worn (or the chain tensioner ceased up) then you may be able to hear a rattling sound from the front cover of the engine.
Electrical causes(petrol engines)
If the timing of the spark in a petrol engine is not just right, it could cause a back fire. The correct setting of the ignition timing becomes more critical as the speed of the engine increases; the faster the engine revs then the more frequent the backfires will become. The ignition timing can be out due to the looseness of the distributor having caused it to rotate a little; the contact points may be damaged or the gap incorrect.
Finally, it is not unknown for the spark plug leads to be replaced occasionally in the wrong order after having removed them.
* copied from an australian LR page
Old Mar 6, 2017 | 03:02 PM
A new contract at work and the fact that I am very frustrated with the Disco II prevented me from working consistently on this issue. So, let me update this thread.
As of today, it's still not running. The same: crank, but it won't start. The fuel pump is good and I have good PSI. The new crank position sensor didn't solve the problem. Current at the spark plug wires was "weak", so I replaced both coil packs and wires. That didn't solve the problem either. The current it's still weak.
I was thinking replacing the engine computer, but it is my understanding that if I replace the computer, it will require reprogramming. Is that true?
I was told that the problem could be the fuse box. Last year I replaced the interior fuse box (with a used one) because it wasn't sending current to the A/C blower motor. After I replaced it, the A/C came back to life and everything was working fine. I still have the original interior fuse box (the one that made the A/C motor blower inop). Before I spend and waste more time and money, I am going to re-install it this week and see what happens.
A friend of mine told me today that he had a similar problem with his Disco II last year. After a lot of work, and testing different components, he ended up replacing the engine compartment fuse box and that solved the problem. I guess that I may try that as well if replacing the interior fuse box doesn't work.
If nothing works, it looks like this is going to be a parts car very soon...
