Disco 2 dim lights not working?
Old Nov 9, 2017 | 06:38 AM
oaty's Avatar
Default Disco 2 dim lights not working?
Got my 2000 disco 2 in September. The radio only comes on after I turn the head lights on. Only the High beams come on. When I switch to dim. Nothing. I have replaced the fuses under the steering wheel and under the bonnet. What's next? I pulled both bulbs out of the headlights. They appear to be in good order. Asking if anyone has had this happen and if their is a simple fix.
Thanks in advance.
Oaty.
Old Nov 9, 2017 | 06:51 AM
zoltan7's Avatar
You're 100% certain you replaced both fuses? I would check them again with voltmeter.
The next obvious spot would be the relays (I think these guys have relays for headlamps)
Old Nov 9, 2017 | 08:14 AM
oaty's Avatar
Default Double check
I will double check...thanks.
Old Nov 10, 2017 | 07:16 PM
hugo81's Avatar
Thanks in advance.
Oaty.
hello I have a similar issue.. my disco2 does not turn the high beams on when the lights are off. But with the low beams on it changes to hi/low!
Is this the relay? Does anyone knows what’s the relay number please?
thanks
Old Nov 14, 2017 | 06:20 PM
hugo81's Avatar
thanks
anyone can help me please?
thanks in advance
abran
Dec 7, 2019 08:07 PM
booper169
Mar 20, 2019 09:37 PM
zigzag3141
Apr 13, 2017 12:47 AM
dparham
Jan 21, 2015 02:36 PM
xtina01
Aug 9, 2012 11:22 AM
