Electrical DII Lights Dim when Horn Activated
Old Dec 15, 2014 | 08:46 PM
dparham's Avatar
Default Electrical DII Lights Dim when Horn Activated
ok Ive been fiddling around for awhile with an electrical issue... brake light do weird things... now noticed when I push horn at night my lights dim, and also when selecting my fog lights seems one headlight goes out partially lol ... m Ultraguage shows 13.8v charging... I had to replace battery once about a year ago... using an Interstate Battery but don't seem to be having starting issues... well once I did but I attributed that to fiddling around with key and half **** turning it... anyway.. could this be a battery issue and also why Im having these electrical anomalies?
Old Dec 16, 2014 | 11:55 AM
dusty1's Avatar
1st thing I would look at is ground connections. good and solid
Old Dec 19, 2014 | 10:39 AM
dparham's Avatar
ok checking monday when I have some time! also will be wiring up 4 700FF roof lights so don't want car to die! haha
whats ironic is I do have weird issues occasionally but repeatable... when turning on left signal or fog lights I get three amigos... maybe this is all connected to a ground... my UG shows 13.8-14.xx so I kind of ruled out alternator and artery is 2 years old... maybe the UG doesn't give me what I thought I was getting...
Old Dec 19, 2014 | 12:22 PM
CollieRover's Avatar
Ok, so I am no expert, but I am reading a book on automotive electrical systems because I need to rewire a knock sensor and diagnose a abs front sensor output low code.
This sounds like a Short to positive right out of the book. The example is a lights dimming during operation of other accessories. Lights dim when there is a drop in voltage. So somehow another load is stealing power and using it to operate. If it were a short to ground I believe that the electricity would return to the battery without operating the light.
I would check the wires and see if they were worn through somewhere.
Old Jan 21, 2015 | 02:36 PM
dparham's Avatar
I picked up one of these ABS dongles ( coming soon) from a member here and Ill be checking but he also thinks a ground..
xtina01
Aug 9, 2012 11:22 AM
03discoman
Jul 12, 2010 07:03 PM
lipadj46
Aug 13, 2009 07:47 PM
Old School
Apr 17, 2008 10:47 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
