Disco 2 Fuel Door clip install
Old Feb 22, 2014 | 05:08 PM
Sykman's Avatar
Default Disco 2 Fuel Door clip install
Ok, broke off the first one of these I bought so took my time on the second one and got it in. Here's what I did for anyone else needed to replace this cheap little clip.
1) First thing I did was soak the new clip in boiling water for a few minutes. This was all that was needed to get this clip just a little more pliable.
2) Start by inserting the rectangular clips little tang into the rectangular slot but make sure you have the circle clip tab pointing straight up. It might take a little bit of wiggling and pressure, but this is why you heat the piece up a little first.
3) Once the rectangular clip is in completely, you can rotate the entire clip clockwise until the round clip lines up with the round hole. Once lined up, just push the round clip in.
4) Final step is to make sure the metal bracket is as close to the plunger pin as possible. All that is needed is some slight pressure to bend this tab into the correct position.
5) Enjoy - until this cheap crappy designed piece breaks again.
Attached Thumbnails Disco 2 Fuel Door clip install-photo-1.jpg   Disco 2 Fuel Door clip install-photo-3.jpg   Disco 2 Fuel Door clip install-photo-4.jpg   Disco 2 Fuel Door clip install-photo-5.jpg
Old Dec 20, 2017 | 03:06 PM
Steve8829's Avatar
Default Fuel door
Thank you for this informtion. I followed your steps..it worked perfectly.
Old Dec 21, 2017 | 12:31 AM
Lisa Bunch's Avatar
I'm using a speaker magnet to keep my door shut...
Old Jun 2, 2018 | 05:59 PM
Disco_Ky's Avatar
Sorry to revive the old thread but I recently replaced the clip and upon installation it simply flips down toward the ground and the peg, therefore, routes up above the correct channel.
As an interim solution I've simply been using my knife to push the clip into the correct position right before closing. But any insight into how to remedy this would be greatly appreciated.
Old Jun 2, 2018 | 09:03 PM
Twix's Avatar
I just bent the metal tab slightly to keep the plastic clip where it should be
Old Jun 2, 2018 | 09:36 PM
Friday Night Disco's Avatar
same here, I had to bend a couple times to get the right angle
Old Jun 4, 2018 | 02:54 AM
shanechevelle's Avatar
I paid $8 at the dealer. Bought 2 in case it happens again.
Old Nov 4, 2018 | 05:33 AM
Jim Richardson's Avatar
Default Thanks
Thanks for the great tutorial and photos. I've now got a fuel flap that works and looks miles better. Cheers
Disco_2000_24
Jun 24, 2019 06:00 PM
expedio2005
Dec 7, 2012 11:50 AM
Ted Hill
Apr 16, 2011 06:08 PM
nynole
Feb 14, 2008 05:21 AM
Disconoobie
Nov 10, 2007 08:49 PM
