disco 2 gearbox oil leak
Old Jul 5, 2012 | 05:59 PM
thomo's Avatar
Default disco 2 gearbox oil leak
ive got a oil leak on the top of my gearbox. i recently had oil and filter changed by land rover and now i've a leak on the top of the box. land rover are saying 3 hours to take the box out
Old Jul 5, 2012 | 06:16 PM
Bkreutz's Avatar
Sounds a bit too coincidental to me. Might be worth a second opinion unless you want to crawl under there and see if you can determine the origin. I'm assuming it's an automatic (because you mentioned filter, we didn't get any manual DII's here). There is a vent line on the top of the trans (actually it's on the left side 3/4 of the way up) that could be leaking, and there's a trans oil cooler pipe that fits into the left side up high as well (almost said drivers side, that would have really confused things in this case). Neither one of those would require trans removal. Ask them specifically what is leaking(rather than the generalized, "the gearbox is leaking"), if they don't know, find another opinion.
Old Jul 5, 2012 | 09:06 PM
So, how mechanical are you?
There should only place where the tranny can leak on a 03 and that would be the vent hose.
Old Jul 5, 2012 | 11:03 PM
Bkreutz's Avatar
The trans has cooler lines that are under pressure, the 03's don't have an engine oil cooler but they do have a trans cooler. One of the lines is on the bottom forward part of the trans and the other is on the left side 2/3 of the way up on the rear part of the trans. The vent line is just that a vent, while it might drip a bit of oil from the oil mist in it, but it shouldn't have any significant amount of oil in it unless it was overfilled. (which is another possibility in this case)
Offroadss350
Oct 26, 2012 04:43 PM
marrapo
Aug 23, 2011 07:28 PM
SonicJunior
Defender
Sep 26, 2006 12:31 PM
JKK
Oct 20, 2005 09:07 PM
