Disco 2 issues
Old Nov 22, 2022 | 05:27 PM
  #21
Ryanok's Avatar
I got the diff fluid changed out to 85 140 with blue devil rear main seal .
seafoam did the trick on the engine removed the sludge so I was able to change the oil. Running good now.
Old Nov 22, 2022 | 05:29 PM
  #22
Ryanok's Avatar
Next up for the 2500 rig
shuttle valve
lift
tires
Old Nov 23, 2022 | 08:10 AM
  #23
Elderair's Avatar
I often see a catalyst efficiency below threshold code when i'm troubleshooting for plugged catalytic converters. That is a fairly big clue and it is set by the difference between the upstream and downstream O2 sensors. Where it may just be a bad O2 sensor it can also be an actual plugged or bad converter. Not definitive but a good clue as to where to look. Obviously the visual inspection is a better test of the converter.
SWM
Feb 7, 2022 01:51 PM
MC04DII
Jun 28, 2013 12:12 AM
Double J
Dec 27, 2009 03:32 PM
humroot
Mar 4, 2009 08:58 PM
SpeedAgent
Jul 27, 2007 01:20 PM
