Disco 2 jack points - chassis longitudinals
Old Sep 28, 2022 | 11:11 AM
disco_nap's Avatar
Default Disco 2 jack points - chassis longitudinals
Hey all. Looking at the jack points in the shop manual, there's a reference to putting jack stands under the "chassis longitudinals". I can't find a good pic or video of what I'm aiming for with those. Does anyone know of one that I can reference?
Thanks
Old Sep 28, 2022 | 02:05 PM
ahab's Avatar
I believe this refers to the long sections of frame that run front to rear.
Old Sep 28, 2022 | 05:28 PM
mollusc's Avatar
Longitudinal = lengthwise along the body of the truck. Chassis = the solid bits of the undercarriage. It should be pretty obvious what those huge pieces of steel are when you look under there.
Old Sep 28, 2022 | 09:38 PM
disco_nap's Avatar
Ah yep, so, that's what I assumed at least inside the front and rear axles (i.e. between the anterior of the rear axle and the posterior of the front axle). What was throwing me off is this illustration and description suggesting that there's something I should be looking for behind the rear wheel (i.e. posterior to the rear axle).
chassis longitudinal reference
Old Sep 29, 2022 | 04:38 AM
mollusc's Avatar
The longitudinals definitely continue past the rear axle, but they start to curve upwards close to the rear so I wouldn't consider this a good candidate for lifting. You can see the rear part of the chassis in the still picture at the top of this blog thread: https://www.autoblog.com/2014/04/02/...e-lapse-video/
Old Sep 29, 2022 | 08:14 AM
Sandman614's Avatar
Sure makes it easy to access those coil packs
Old Sep 29, 2022 | 08:15 AM
Sandman614's Avatar
@disco_nap Why not just lift from the axles or the frame? Are you just bored reading the manual?
Old Oct 2, 2022 | 07:41 PM
Best4x4's Avatar
The lower radius arms have notches in them for the OEM LR Bottle Jack. Makes jacking up a D2 a breeze in that location or place the jack directly under the F/R axle housing.
A Faceless Man
Apr 13, 2024 12:38 PM
Pangea123
Aug 25, 2023 04:00 PM
DPReef
Mar 28, 2023 06:49 AM
LR2driver
LR2
Feb 24, 2023 06:50 PM
4x4 Brad
Feb 20, 2016 08:37 AM
