Disco 2 with P38 engine thats leaking from the front?
Old Dec 16, 2016 | 09:54 PM
  #21
Fast951's Avatar
I have seen some cases where the cam sensor wires in the connector actually push out of the rear of the connector when plugging the sensor into the harness. Make sure the plugs go together smoothly and snap together. You might even want to use a bit of silicone grease on the inside of each connector.
Old Dec 18, 2016 | 03:08 PM
  #22
2 discos's Avatar
That is pretty cool.. I was actually thinking about installing my 96 Range Rover P38 4.0 in my 03 disco se7.. but I wasn't sure if the engine would match up to the 03 transmission and I was thinking about sticking the transmission for my 96 P38 into my o4.. is it possible? I've actually started a new thread but nobody has answered me yet and I'm new to this and any help would be greatly appreciated thanks
Old Dec 18, 2016 | 03:43 PM
  #23
Charlie_V's Avatar
The transmission will bokt up but there may be more to it. The 03 has an electronic transmission, so it needs inputs from the crank sensor and the throttle position sensor. Doesn't the 1996 P38 have a GEMS engine? You might have to adapt some sensors... not sure. I'm sure it is doable though, but maybe with some extra work.
jhill15
Jun 7, 2013 08:06 AM
ESPN
May 3, 2012 07:42 PM
dancedisco
Feb 29, 2012 04:49 PM
jycsalas
Apr 3, 2009 03:52 PM
BADBUZzZzZz
May 12, 2008 03:07 PM
