Disco 2 Rolled into ditch now Engine won't start
Hi. I hit a patch of black ice and came off the road ending 3/4 up in a deep ditch full of mud and icy water.
A friendly farmer hauled me upright and out about 3 hours later.
And a pick up towed me to a local garage.
Windscreen gone cab wet and muddy a few dents.
But the TD5 Diesel engine won't turn over.
Is there any point trying..or is it not worth wasting the time effort and expense?
If it was upside down for 3 hours, the crankcase oil could (and probably did) leak past the piston rings into the combustion chamber. This would hydraulic lock the engine (liquids can't be compressed). Have the mechanic make sure the engine can be rotated with a wrench. If this is the case, the oil will eventually leak down back into the crankcase but not as fast as when it's hot. The injectors (or glow plugs) can be removed and the engine turned over manually to clear the liquid. If this turns out to be the problem and the shop you took it to didn't think of this, take it somewhere else.
Even if it was a 3/4 roll over if the intake side was in the water when it was righted the water could have gotten into the cylinders and hydro-locked it.
And buy "wont turn over" we are assuming he means he turns the key and the engine will not move, the starter binds and thats all.
If he means the starter does nothing then we are barking up the wrong tree.
charliesdiscovery
06-06-2008 02:39 PM
