Disco 2 Second Battery
Old Jan 12, 2022 | 05:19 AM
brydonsearle's Avatar
Default Disco 2 Second Battery
So i have a second battery location in the engine bay of my disco 2 but im
not sure what it does because it doesn’t have a battery in it and it doesn’t have any accessories or locations for accessories so any ideas on what it’s for?
Old Jan 12, 2022 | 05:47 AM
Alex_M's Avatar
Could you upload us a picture? To my knowledge a dual battery setup was never an option on the D2.
Old Jan 12, 2022 | 05:57 AM
mln01's Avatar
An aftermarket dual battery tray was available several years ago. The seller was Columbia Outfitters, or a name similar. Long gone.
Old Jan 14, 2022 | 08:33 PM
DonRW2007's Avatar
I sure wish I could source one of these - looked close to an OEM option. Missed the chance.
Old Jan 14, 2022 | 09:49 PM
greisinb's Avatar
A second battery is typically charged by your alternator through a switch (automatically or manually controlled) called an isolator. When you stop to make camp the switch turns off (or you turn it off) and you can now draw power from the battery without running your main battery down. This does mean you need to have a secondary electrical system rigged up in your vehicle, perhaps the PO took all of those parts? Post a picture and perhaps we can see something.
I’m envious of an “under the hood” solution. My secondary battery is mounted way in the back in the passenger side storage cubby. I know a few aftermarket folks made a secondary battery try a while back but they’ve all gone under as far as I understand. If you don’t want it you could always post it for sale here, I’m sure one one will take a bite at it!
Old Jan 15, 2022 | 03:09 AM
Gripen's Avatar
If it's the OEM battery tray, then I feel you're talking about the space behind the battery? If so, this is where the original bottle jack was secured.
Old Jan 15, 2022 | 07:46 AM
Alex_M's Avatar
I have considered removing the factory battery tray and building a dual battery setup. It's something I would consider selling in a small batch if a few folks were interested.
Old Jan 15, 2022 | 11:26 AM
Sean Maginness's Avatar
Rasies hand for being interested. I'm currently running an Optima Red Top with dual posts to account for additional accessories. That physical sized battery leaves a lot of space and I keep eyeing that area for a dual battery set up.
Old Jan 15, 2022 | 03:44 PM
acg's Avatar
acg
Here is some good info on the use of the Columbia Overland dual tray. Unfortunately, they went out of business:
Dual Battery and 12v Distribution ? Caroline and Stephen
Old Jan 15, 2022 | 04:25 PM
SundayFunday's Avatar
Pretty easy to do. The space is there up front if you rid the jack..
i elected to use a dual battery solenoid isolator system, ( iTHINK the old veteran guru on here Disco Mike went by simply linking them parallel..) which wouldn’t have been more then salvaging a single battery cable from junkyard & some dual terminals..
mmbirtcher
LR4
Oct 13, 2021 04:27 PM
pllr
Jul 9, 2021 02:31 PM
Shadow993
Oct 24, 2019 11:55 PM
LR03NJ
Nov 12, 2012 03:16 PM
yarddawg
Jan 15, 2008 07:40 PM
