Disco 2 stall **Help appreciated**
Old Nov 15, 2021 | 06:33 PM
NickS's Avatar
Default Disco 2 stall **Help appreciated**
Discovery 2 stalls at only at idle. Sputters backfires and dies Hot / cold doesn't matter.
New IAC / Stepper motor, still stallsRepinned bank 1 sensor 1 o2 sensor previous owner used universal sensor got 4 from Atlantic British, still stallsNew MAF still stalls, tried with MaF unplugged still stalls
Checked for vacuum leaks with smoke tester none found.
Finally I dropped the exhaust after the manifold at the downpipe, lowered it an inch ran it without the cats, idles fine just loud af my ears!!
Could this be plugged / bad cats? Typically I have found a vehicle won't rev in the past not idle with a bad cat,
Input appreciated
Old Nov 15, 2021 | 06:54 PM
NickS's Avatar
btw truck has 8mm wired and plugs gapped correctly with a feeler gauge
Old Nov 15, 2021 | 08:29 PM
Best4x4's Avatar
If it runs fine with the Y pipe disconnected then I'd suspect the cats or a clogged muffler yes. I had my 95 D1 give me a crazy bogging situation or wouldn't rev past 3K and it turned out to be a broken aftermarket Y pipe cat.
Old Nov 15, 2021 | 09:09 PM
NickS's Avatar
So weird,
it Revs fine I have to rev it to keep it running,
with the Y pipe dropped yeah idles fine And Revs
Any input on if I clamp some straight pipe to replace the cats until I can afford a new Y Pipe Assembly, they are quite expensive to ship up here to Canada
Old Nov 17, 2021 | 11:30 PM
JohnZo's Avatar
PO of my 94 D1 had broken out the ceramic through holes in the cats then welded them back closed. Funny that the aftermarket y pipes I found are made in Canada.
Old Nov 18, 2021 | 06:21 AM
NickS's Avatar
What brand who makes them?
Old Nov 18, 2021 | 07:35 AM
JohnZo's Avatar
I just did a quick ebay search. Looks like a $300 price increase since a few months ago. Maybe they added the shipping costs.
Made in Canada.
Old Nov 18, 2021 | 08:30 AM
mollusc's Avatar
OP has a D2. This is the D2 forum. That's for a D1. So don't order that specific piece.
mafiotulnr1
Dec 4, 2015 11:44 AM
pedronz
Nov 14, 2011 01:51 AM
Optimistic.1
Mar 29, 2011 05:46 AM
Huckleberry77
Oct 8, 2010 05:55 PM
hoberock
Jan 6, 2007 09:51 PM
