Disco 2 stall **Help appreciated**
Discovery 2 stalls at only at idle. Sputters backfires and dies Hot / cold doesn't matter.
New IAC / Stepper motor, still stallsRepinned bank 1 sensor 1 o2 sensor previous owner used universal sensor got 4 from Atlantic British, still stallsNew MAF still stalls, tried with MaF unplugged still stalls
Checked for vacuum leaks with smoke tester none found.
Finally I dropped the exhaust after the manifold at the downpipe, lowered it an inch ran it without the cats, idles fine just loud af my ears!!
Could this be plugged / bad cats? Typically I have found a vehicle won't rev in the past not idle with a bad cat,
Input appreciated
Input appreciated
If it runs fine with the Y pipe disconnected then I'd suspect the cats or a clogged muffler yes. I had my 95 D1 give me a crazy bogging situation or wouldn't rev past 3K and it turned out to be a broken aftermarket Y pipe cat.
it Revs fine I have to rev it to keep it running,
with the Y pipe dropped yeah idles fine And Revs
Any input on if I clamp some straight pipe to replace the cats until I can afford a new Y Pipe Assembly, they are quite expensive to ship up here to Canada
What brand who makes them?
mafiotulnr1
Dec 4, 2015 11:44 AM
