Disco 2 TD5 poor starting
Old Feb 12, 2016 | 04:40 PM
Caravanner's Avatar
Default Disco 2 TD5 poor starting
Can you advise with my starting problem. When starting from cold having stood overnight the engine turns over for ages before it starts with unburnt diesel smoking. I always wait for the glow plug light to go out and allow another 5-6secs before turning the key. The glow plugs have been replaced, the injectors have been checked by specialists and a new fuel filter fitted. The battery is new and turns over well. The glow plugs take same current as another Disco that starts immediately. The relay has been changed to eliminate. Once started it runs well and will restart without any problems. Any ideas?
Caravanner
Old Feb 13, 2016 | 05:55 AM
Alex_M's Avatar
Maybe someone with some general diesel experience will drop in, but I don't know of more than one or two people here that live outside the US, so pretty much all the members only have the gas V8 Discoverys and therefore not much knowledge on the workings of the TD5.
Old Feb 13, 2016 | 09:36 AM
number9's Avatar
If you've owned this vehicle for several years and this just started? Have owned several non LR diesels. When cold enough to contribute to hard starting I'd often go through two glow plug cycles and crank starter immediately after light goes out. Waiting 5-6 seconds may allow temp to drop too much.
pgaukroger
Feb 29, 2016 05:56 AM
Kandow
Aug 19, 2009 05:46 PM
OxyCoRover
Aug 7, 2008 04:14 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
chelski
Freelander
May 10, 2006 02:44 PM
