Disco 2 Tie rod end
Old Oct 5, 2015 | 12:45 PM
DiscoCam's Avatar
Default Disco 2 Tie rod end
I was just wondering if tie rod ends are common issues on D2s. They seem pretty firm on my Disco.
Thanks.
2004 Discovery II SE Java Black
Old Oct 5, 2015 | 12:56 PM
Alex_M's Avatar
I'm not exactly sure what you mean, but I believe you're asking if they're usually hard to get off. I'd say yes, but no more than most vehicles after 15 years. Also, I'd recommend replacing the entire drag link and track bar because only one end on each is replaceable. The other is welded. I got both of mine from lucky 8, less than $70 for one (I think) and I can't remember the price of the other.
Old Oct 5, 2015 | 02:21 PM
ZGPhoto's Avatar
Failure rate is around 100% over time.
Old Oct 5, 2015 | 07:34 PM
DiscoCam's Avatar
Thanks for the replies. I was just wondering if this was another ingeniously engineered part like the front drive shaft or the cylinder liners. I've never had a tie rod fail on any car, and I had a 2001 Toyota Sequoia with 352k.
Old Oct 7, 2015 | 07:17 AM
drowssap's Avatar
this is what happens when you don't put grease fittings on movable parts.
but what early make the D2 stand out is if the TRE's get bad enough the bar will make contact with the rim.
TRIARII
Feb 21, 2013 10:33 PM
Cottrell
Sep 20, 2012 01:24 PM
Clunker
May 9, 2011 08:16 PM
Christian_X
Oct 27, 2008 05:54 PM
jcw
Oct 27, 2006 08:26 PM
