Disco 2 u joints
Old May 30, 2011 | 05:06 PM
antichrist's Avatar
Originally Posted by Turd Ferguson
I realize this is a dead issue, but when checking the front prop myself I found that the u joint going into the transfer case is wiggling around and looks as if a divot has been dug into the shaft inside the joint where they lock together. Also I can turn the shaft by hand about 20 degrees. Is this the same issue that this thread is referring to? I see a zerk fitting on the shaft towards the t case. Does this mean that the shaft has been rebuilt before? It's a 94 Disco I.
https://landroverforums.com/forum/ge...rebuild-29302/
Read it.
DII's are the ones with the biggest issue with propshafts, but anything in the above post that isn't about the double cardan also applies to the D1.
discosam
Jun 19, 2010 03:39 PM
avking
Feb 3, 2009 07:04 PM
roadshadowww
Jan 15, 2009 08:44 PM
Phototone
Apr 24, 2008 05:15 PM
porschebreath
Aug 7, 2007 09:56 PM
