Disco 2 won't start. Immobilized
Old Feb 23, 2015 | 07:42 PM
jrwalk1651's Avatar
Default Disco 2 won't start. Immobilized
Hi,
I've read all the stickies and have tried all the codes but can't get anything to work. This morning I went to go start my disco and I turned the key the engine attempted to start for a second and then alarm went off and stopped the engine from starting. I took a different car to work and got home and tried to start it again. This time it wouldn't even turn over and the led dash light was blinking rapidly. All the lights on the dash work except for the radio. Does anyone have any other suggestions? It's a 99 disco. Thanks a ton!
Old Feb 23, 2015 | 11:29 PM
cappedup's Avatar
Battery voltage ok?
I don't know specifically about immobilization, but low battery condition can monkey around with a lot of things.
I had my horn blaring and the doors locking when I had poor battery condition recently.
Old Feb 24, 2015 | 05:50 AM
jrwalk1651's Avatar
Originally Posted by cappedup
Battery voltage ok?
I may try and pick up a new battery today. It was -6 when I tried to start it. (Chicago) Maybe when it realized it didn't have enough power to start it decided to shut it down and not even try. I'll keep you updated.
Old Feb 24, 2015 | 09:03 PM
jrwalk1651's Avatar
Just a quick update, it was the battery! She's back up and running.
Old Feb 24, 2015 | 10:34 PM
cappedup's Avatar
Sweet.
Old Mar 12, 2021 | 12:22 PM
John A. Altomare's Avatar
I have a 2001 Disco 2 and have had the same issue with the immobilizer twice this week. The battery was low on charge, so after topping off the fluid and charging it, I reinstalled it back in the vehicle. The immobilizer issue remained. After uber-tightening the positive battery cable, the issue cleared. I tried following the steps to enter the generic EKA code using the driver's door lock, and it wouldn't work for me. I'm not sure what to do if/when (probably when) this happens again other than checking the terminals. Any inputs/ideas are greatly appreciated.
mmurphy536
Feb 28, 2024 05:12 PM
daniel_s_brown
Jul 2, 2019 08:02 AM
DiscoUSA
Apr 24, 2017 10:28 PM
grandkodiak
Jan 2, 2013 05:59 PM
hazletbassist89
May 17, 2009 10:14 PM
