Disco 2004 90K: Failed flex Plate and transmission questions, with pictures
Old Oct 26, 2015 | 10:59 AM
Robert Johnston's Avatar
5th Gear
Default Disco 2004 90K: Failed flex Plate and transmission questions, with pictures
Help, I had a severe ATF fluid leak that I initially attributed to failure of the front seal in the transmission. I have pulled the transmission and have the following questions:
1. Flex plate, why did my flex plate fail - see picture
Disco 2004 90K: Failed flex Plate and transmission questions, with pictures-flexplate.jpg
2 On the input shaft, which I think is the splined shaft shown coming out of the transmission in the following picture, the axial end-float should measure 0.2 to 0.4 mm(0.008 to 0.016 in.).
Disco 2004 90K: Failed flex Plate and transmission questions, with pictures-discovery457.edited-fore-aft.png
Have I understood the manual in that the axial end float is measured fore to aft, from the torque converter towards the transfer case?
3. What should my radial run-out be on the same shaft, see picture:
Disco 2004 90K: Failed flex Plate and transmission questions, with pictures-discovery457.edited-2.png
4. Should the splined shaft indicated by the red arrow turn, and if so how easily, see picture:
Disco 2004 90K: Failed flex Plate and transmission questions, with pictures-916-torque-converter-edited-3.jpg
5. How easily should the ATF pump turn?
Old Oct 26, 2015 | 11:49 AM
drowssap's Avatar
a cracked or broken flexplate it is not an uncommon problem, i have probably seen 6 or so on here
Old Oct 26, 2015 | 11:54 AM
5th Gear
any manufacture's or distributor's flex plate recommended to avoid this in the future?
Old Oct 26, 2015 | 12:00 PM
drowssap's Avatar
i would just grab a used one from Paul Grant to be honest
Old Oct 26, 2015 | 12:43 PM
Paul Grant's Avatar
I have them if you need one.
Old Oct 26, 2015 | 07:55 PM
Agodofgame's Avatar
6th Gear
Just out of curiosity, anyone know how frequently do the flex plates crack or brake on the disco 2s?
Old Oct 27, 2015 | 07:26 AM
Paul Grant's Avatar
All I can say is that I sell every one I pull that's in good condition. I can't recall selling many for DI's or RRC's when they were of comparable age.
Old Oct 27, 2015 | 09:16 PM
zeroone's Avatar
I'm dreading that flex plate as I feel mine is on its way out. There is a vibration (shock) in the drive train translating into the entire body. New u-joints, front shaft, rotoflex coupler... still there. Only thing left I can think of is that damn plate.
Old Oct 27, 2015 | 10:32 PM
Alex_M's Avatar
I don't suppose a D1 or RRC plate would fit?
Old Oct 28, 2015 | 02:30 PM
NVDiscovery's Avatar
New flex plates are $45 so why buy a used one? How many hours of labor to install the new flex plate?
