Disco 60,000 mile service??
Old Sep 7, 2008 | 06:25 PM
IDAHODISCO's Avatar
Default Disco 60,000 mile service??
Does any one have a list of what needs to be done on the 60,000 mile service? I know I have seen it on hear befor! Thanks
Old Sep 7, 2008 | 06:44 PM
Default RE: Disco 60,000 mile service??
It is listed in your Passport to Service book.
Oil change, transmision service, t-case and diffs, brake fluid, plugs and wires, air filter, tire PSI, lube all of your locks and hinges.
You are right though, it is listed on here somewhere.
Old Sep 7, 2008 | 07:07 PM
You need to research a little so we don't have to do it for you.
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it.
1 Oil filter, K&N 3001 or Mobil 1
1 Air filter
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W synthetic gear oil
1 Qt of synthetic Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Old Sep 7, 2008 | 07:11 PM
IDAHODISCO's Avatar
Thanks guys I did some of it allready but the big stuff!
wisconsinoverlander
Sep 21, 2012 11:23 AM
tibetrover
Jul 19, 2010 10:27 AM
marlymarl
Aug 20, 2008 11:33 AM
triggersd
Apr 27, 2006 08:15 PM
VB_Rover
Jun 9, 2005 12:49 AM
