disco doing weird things
Old Dec 21, 2007 | 10:58 AM
Brokenrover's Avatar
Default disco doing weird things
last week my disco died on the road by stalling and starting back up only to stall again. I had It towed to an independent land rover service and they can't seem to fix it. They replaced the crank sensor and now it runs with a slightttt shake in the idle but it runs. Here is the weird part, when you turn the heat/AC on and it stalls. I recently installed HID lights could the balast location be the culprit? Is that just a coincidence? Please help If you can I need heat in NY LOL. The disco is a 2004 with 56k miles. Thanks for any help
Old Dec 21, 2007 | 11:00 AM
Default RE: disco doing weird things
by the way, the car showed no codes they said
Old Dec 21, 2007 | 11:54 AM
So, the check engine light is not on?
Then I would suggest you clean the t/body and idle control unit, this should fix it.
If you don't know how and don't want to pay the mechanocs then call me and I'll walk you thru it.
303-862-7680
Colorado between 7am and 8pm
Old Dec 22, 2007 | 01:28 AM
Mike you are the best, thanks. I'll take you up on that are you free saturday afternoon or will you be busy with the holidays? The check engine light came back but car seems to still run fine if I don't use the heater.
Old Dec 22, 2007 | 08:54 AM
So, go to the auto parts store near you get the codes read for free, send me the code numbers and buy a can of carb spray.
Old Dec 22, 2007 | 12:52 PM
Mike, I am going in about 20 minutes to autozone to get codes read and to buy the carb cleaner. Is this a job that a moron like myself can do? I was able to install HIDs so I'm not thattt bad. I will let you know the codes ASAP and again, thanks for the help. I shelled out $500 for the place to leave my car still broken.
Danny
Old Dec 22, 2007 | 02:11 PM
ok mike I'm heading back home now the codes are P0102 and P1884
Prepilot_3ck
Apr 7, 2015 02:08 PM
Jared9220
Dec 3, 2014 06:44 AM
RoveringAgain
May 19, 2009 11:41 PM
Brad S1
Jun 8, 2007 05:41 PM
Doral300sc
Feb 25, 2006 11:32 PM
