Disco Factory Stereo Stuck
Old Aug 4, 2012 | 09:13 PM
Cincy1's Avatar
5th Gear
Default Disco Factory Stereo Stuck
The factory AM/FM on my 2000 Disco 2 is stuck on one specific station, and at low volume. The stereo buttons do absolutely nothing, and neither do the steering column controls. Is there some quasi-unknown super-secret way to reset the thing to defaults, or to jump-start it to normal operating? I don't have a manual for the truck to refer to.
Old Aug 5, 2012 | 04:35 AM
Download the RAVE in my signature links and you will have all the manuals for the truck, including how to pull radio if you wish. Wiring diagrams will show connectors for remote buttons that may need to be disconnected.
Old Aug 5, 2012 | 11:36 AM
Cincy1's Avatar
5th Gear
Thanks a bunch! The manual revealed much hither-to unknowns about the truck itself. Unfortunately there wasn't a troubleshooting section to list some common ailments and remedies for on-board systems, such as the stereo. Any ideas on my stereo's refusal to change stations or volume?
Old Aug 5, 2012 | 12:31 PM
The radio most likely has internal damage, might want to call the link listed below and ask them if they can repair it.
Old Oct 26, 2012 | 06:28 PM
MannyTaz's Avatar
Thanks for the post Manuals are a great resource. Getting a 95 Dico back into shape and these will come in handy
Old Aug 16, 2021 | 07:07 AM
Disco662's Avatar
Default Ever figure it out?
[Im currently having same issue with my 04 Disco 2. Ever get it figured out?
QUOTE=Cincy1;335954]The factory AM/FM on my 2000 Disco 2 is stuck on one specific station, and at low volume. The stereo buttons do absolutely nothing, and neither do the steering column controls. Is there some quasi-unknown super-secret way to reset the thing to defaults, or to jump-start it to normal operating? I don't have a manual for the truck to refer to.[/QUOTE]
Old Aug 16, 2021 | 01:57 PM
shatterbrained's Avatar
My factory radio would frequently get ornery. Always if I pulled it out and reset the fuse in back of the radio it would right itself. You'll need the keys to insert into the sides to get the radio out. Your mechanic may let you borrow them if you ask.
However I have since replaced it with a flip out Apple Play unit that is wonderful!!!! Look for single din.
Old Aug 16, 2021 | 03:35 PM
mln01's Avatar
The steel supports from a hanging file folder also work pretty well to insert into the slots and release the tabs holding the radio in place. It takes a little fiddling but it works fine.
Jeff Hughes
Jun 10, 2019 10:25 AM
XCore
Feb 29, 2012 06:26 PM
drowssap
Apr 1, 2011 11:59 AM
mx468
Jan 17, 2011 07:36 PM
meltdowndave
Apr 21, 2008 07:39 PM
