Disco I radiator
Old Aug 30, 2007 | 07:48 PM
Craig's Avatar
Default Disco I radiator
I sprung a leak in my radiator so I have that $467 beauty to look forward to... My question is, since it's 11 years old (1997 model year), should I replace the water pump (original one is still in there) and the thermostat (cheap), while I'm at it...? Or do the water pumps last a while? She has 106k miles on her. I've been told to stay away from rebuilt radiators and go with the factory equipment. Land Rover Miramar in San Diego was actually $100 less then my personal mechanic ($467 vs. $567). Any thoughts on this or know of a reliable website for comparable units.
Thanks in advance,
Old Aug 30, 2007 | 08:19 PM
Default RE: Disco I radiator
With your mileage, if it were me, I would probably do the whole enchlada, I am surprise your water pump is still hanging in there.
Old Aug 31, 2007 | 08:02 AM
Craig's Avatar
Thanks Mike, I will do as you suggest. Question - Any thoughts on after market radiator or water pump...? My gut tells me to step up and go factory equipment and be done with it...
You should post a picture of your vehicle, it sounds sweet.
Old Aug 31, 2007 | 08:56 AM
I would go with a factory water pump but I am not real keen on their radiators.
There have been some great deals on radiators on e-bay from time to time, past that i would call around and talk to different radiator shops about what they might have available as an after market radiator.
Good luck,
Old Aug 31, 2007 | 10:10 AM
98roverguy's Avatar
I use this radiator. No problems. http://www.performanceradiator.com/index.phpA bit cheaper as well. I'd replace all your hoses too.
Old Aug 31, 2007 | 11:57 AM
tads's Avatar
My factory rad was complety rotted out from the inside when I bought my 96 SE7 a few months ago. I bought an aftermarket from Roverland Parts and it's been doing fine. Just 2 cents...
Old Aug 31, 2007 | 05:32 PM
okdiscoguy's Avatar
ORIGINAL: tads
Roverland parts sells used stuff. Did they start carrying aftermarket rads?
littleus2001
Aug 5, 2008 06:32 PM
erubin
Jun 19, 2008 02:46 PM
wooz797
Apr 7, 2008 04:06 PM
2003Disco2
Jun 15, 2006 01:46 AM
nickvillaume
Jul 19, 2005 01:52 PM
