Disco II (2002) door speakers
Old Jul 11, 2007 | 08:42 AM
SpeedAgent's Avatar
Default Disco II (2002) door speakers
Does anyone know what size speakers are in the lower portion of the door? I have a non-HK system. Also, what's the easiest way to get to them withouth screwing up the door panel?
Thanks
Old Jul 11, 2007 | 11:52 AM
Randy Lover's Avatar
Default RE: Disco II (2002) door speakers
im not sure of the size but youve got to unscrew the door pannel and pull it away to get to the speakers, unless you pry off the speaker grill, but that will just give you the face of the speaker which probably wont be very helpful
Old Jul 11, 2007 | 12:54 PM
puchungozback's Avatar
The speaker size is 6 1/2 inches. You need a special tool used by all audio install techs to pry the panel with out scratching of breaking the corners. Looks like a curved flat head screw driver. Thats the only tool that wont scratch the edges. Hope this helps.
Old Jul 11, 2007 | 03:25 PM
SpeedAgent's Avatar
It's strange that the door woofers are larger than the subs in the rear door (6").
Old Jul 12, 2007 | 02:17 PM
to be honest your hardly notice the rear subs anyway unless your sitting with the enginge off or you put your hand on the rear reg plate. only when you have the volume realy cranked up can you feel the bass
Old Jul 15, 2007 | 10:46 PM
Nokeman's Avatar
Does anybody know what size the little tweeters on the A pillar are? What about the smaller speakers right in the middle of the door?
LRD2pdx
Mar 9, 2014 08:23 AM
kchao2000
Freelander
Nov 13, 2007 09:30 AM
bklahl
Aug 9, 2006 07:36 PM
dherbs85
Nov 25, 2005 02:38 AM
slamwhit
Jun 18, 2005 02:13 AM
