Disco II ABS Sensor Problem - Please Help
Old Dec 10, 2016 | 12:13 PM
rappo999's Avatar
Smile Disco II ABS Sensor Problem - Please Help
Hi,
This issue is one a 2001 DII 165k mi. Truck is a daily driver and has had no warning lights or major issues for a couple of years since 3-amigos fixed.
Needed wheel hub replacements. Ordered new hub assemblies with ABS sensors already attached as part of the package. Installed last weekend - no issues except had to spend too much time on right side hub nut. Buttoned it all back up and the ABS light is on.
I have not driven it except back and forth in the driveway. No error codes on normal code reader, took battery lead off for 10 min. Still ABS light on.
I ordered a pair of replacement sensors. I figured if I was going to take it all apart again, I should have new sensors on hand. I plugged the 2 new sensors in (leaving them hanging) and still have ABS light on with the new ones.
SO... What to do next?
I did some research and some people say that the sensors need grease on them - is that true? What kind of grease, etc?
Do the sensors need to reset somehow? Should I just drive the truck for a while?
Should the sensors hanging (not mounted) work, or do they need to "see" the hub? Is there any way to test the sensors before I take it all apart again?
Any other ideas?
Anyone want to buy a DII with an ABS problem? :-) I might be getting too old to spend every third weekend under the two Discos I own.
Any help will be greatly appreciated! Thanks in advance...
Jason R
Glenside, PA
1997 DI (Sebastien)
2001 DII (Grover)
2008 RR (Grey Lady)
KlamathMatt
Apr 17, 2020 05:27 AM
LADEROUTE
Mar 12, 2014 08:58 PM
sawadeh
Jul 2, 2011 08:10 PM
twaszak
Jun 4, 2011 07:49 AM
