Traction Control noises
Old 08-11-2008, 02:22 AM
DiscoDrew's Avatar
6th Gear
Default Traction Control noises
Hi Guys,
Well, I finally managed to get my Disco II into the bush on the weekend when I went camping in the Chichester State Forest in New South Wales. The whole car seemed to come alive and was a totally different vehicle to the work hack that I drive each day. However, I have aquery that hopefully, some of the guys on the forum might be able to help with.
Basically, it's the traction control,in some of the rough stuff, the TC light comes on for a few seconds as it describes in the Owner's Manual, but it also makes loud whirring noises at the same time - is this normal or is it indicative of something wrong?
cheers
Andrew
Old 08-11-2008, 07:22 AM
bearcatfans's Avatar
Default RE: Traction Control noises
Completely normal.
-aaron
2003 SE7 Disco II
Old 08-11-2008, 07:44 AM
Urban Panzer's Avatar
Yep, completely normal, what your hearing is the ABS pump, pumping the fluid to brake the spinning wheel to givetraction backto the other side.
Old 08-11-2008, 01:51 PM
Switzer's Avatar
What year model is your Disco? I installed a center differential (transfer case) lock handle and removed the sway bars. After this my traction control does not need to work as hard anymore.
Cheers,
Pete
Old 08-11-2008, 02:21 PM
neitherdoes mine, but I have kept the sway bars or "roll bars" as we know themover hereas I have ACE as well
newfrl
Freelander
16
08-27-2020 06:55 AM
matt3502
11-01-2010 10:19 AM
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
Sean 1313
08-30-2005 10:00 PM
Quick Reply: Traction Control noises
