Disco II immobilized....Read this it works!
#21
Take off the driver door panel, remove door handle and insert long phillips screwdriver into recess of door lock actuator to manually lock and unlock door lock actuator. this needs to be done with battery connected. remove horn relay to silence alarm.
Your door lock pin is broken. See here for instructions on accessing actuator/handle.
https://cdn.shopify.com/s/files/1/00...88780856016786
Yelrut (09-03-2018)
#22
Problem solved but I created another problem
#25
#26
Where do I find my EKA code online. I have a 2001 disco 2 that will not start.
Read EKA Code (Freelander up to 01, Defender, Discovery)
Under normal circumstances, the only way to disarm the Immobiliser on a Land Rover
vehicle is to use the correct Plip key to unlock the car. If no Plip key is available or
functioning, it is possible to disarm the Immobiliser by using the EKA (Emergency Key
Access) Code. This option will read the EKA Code from the vehicle and display it on the
Multi-Tester Pro screen.
The EKA Code consists of a 4 digit numerical sequence. To use an EKA code to disarm a
vehicle, perform the following sequence:
Insert the key into the drivers door lock and turn to the lock position.
Wait for 5 seconds.
Turn the key to the unlock position the number of times indicated by the first digit of the EKA code.
Turn the key to the lock position the number of times indicated by the second digit of the EKA code.
Turn the key to the unlock position the number of times indicated by the third digit of the EKA code.
Turn the key to the lock position the number of times indicated by the fourth digit of the EKA code.
Turn the key to the unlock position.
If the EKA code is entered correctly, the Alarm LED will stop flashing, and the engine will
start.
If you make an error while entering the EKA code, open and close the driver’s door before
going back to the start of the sequence. If the EKA code is entered unsuccessfully 3 times,
the system will ignore any further attempts for the next 10 minutes.
Wait for 5 seconds.
start.
#29
Yes, this article has related EKA code info.
https://landroverforums.com/forum/di...98/#post653447
my post and picture: https://landroverforums.com/forum/di...51/#post643202
their post and picture: http://www.foxwellsupport.com/foxwel...-discovery-ii/
#30
where did you get the pin for land rover door
Hi, i am having similar problems as you, where did you get the pin for land rover door?
