Disco II immobilized....Read this it works!
Old Feb 18, 2020 | 09:07 AM
  #31
frarod21's Avatar
3rd Gear
Default Please
Originally Posted by Yelrut
PROBLEM SOLVED. Thank you very much Abran, It was a broken door lock pin, just like you said. I'm soooo excited now! I went from being ready to sell or junk that car to now being ready to tackle the next repair.....LOL. Thank you for sharing your wisdom and your time!
could you explain us how did you solve this problem?
Old Jun 4, 2020 | 06:12 AM
  #32
RoverSE7's Avatar
Default EKA Procedure??
Originally Posted by jafir
Here is a bit more detailed text, stolen from rave:
Originally Posted by southfloridadiscoII
Read EKA Code (Freelander up to 01, Defender, Discovery)
Under normal circumstances, the only way to disarm the Immobiliser on a Land Rover
vehicle is to use the correct Plip key to unlock the car. If no Plip key is available or
functioning, it is possible to disarm the Immobiliser by using the EKA (Emergency Key
Access) Code. This option will read the EKA Code from the vehicle and display it on the
Multi-Tester Pro screen.
The EKA Code consists of a 4 digit numerical sequence. To use an EKA code to disarm a
vehicle, perform the following sequence:
Insert the key into the drivers door lock and turn to the lock position.
Wait for 5 seconds.
Turn the key to the unlock position the number of times indicated by the first digit of the EKA code.
Turn the key to the lock position the number of times indicated by the second digit of the EKA code.
Turn the key to the unlock position the number of times indicated by the third digit of the EKA code.
Turn the key to the lock position the number of times indicated by the fourth digit of the EKA code.
Turn the key to the unlock position.
If the EKA code is entered correctly, the Alarm LED will stop flashing, and the engine will
start.
If you make an error while entering the EKA code, open and close the driver’s door before
going back to the start of the sequence. If the EKA code is entered unsuccessfully 3 times,
the system will ignore any further attempts for the next 10 minutes.
I have the same issue Flashers going off and the truck won't start... Just turns over. I did these steps and has not reset! Well I thought this was the issue anyway. I have never gotten and "alarm" where it has "set off". And i must note that i do NOT have the LED light flashing or anything which is strange.
So when you do the very first step of holding the key in unlock position for 5 seconds.. And i assume truck ignition needs to be off...as most people have the same key for ignition. However I do not I have two keys one for the ignition which has been changed and one for the door . Anyway i do the first step and what i read is that the BCU should make sound realizing that the sequence has begun. All i hear is horn beep immediately as i turn the key rod slot and each successive key turn in the sequence is just a beep. Note* The lock mechanism is out of the truck. and plugged in, so i do it wit the broken rod stuck into the cross hatched lock switch.
So twice i have tried the factory code i received from my Foxwell NT530 Scanner and i can not get this thing to start and the flashers to stop. I just pulled the fuse in order to save my battery. This all started when i was trying to replace the main door lock mechanism which i could not get to work either. Brand new broke? Or was there something else which caused the driver side door not to operate? I also tried that reset of the crash sensor deal on the fire wall... Maybe that is bad as the rubber cap was missing... i took the cap off the spare truck i have but maybe i need to take the whole unit instead?? Again just throwing this out there as nothing is seeming to work to start this truck... and all i wanted to do is fix the supposed bad door lock and broken key rod and now its just a mess that i may just relegate to towing to the LR dealer which i just don't want to have to do... Any other thoughts? @Extinct was helping me on my thread i started for just the lock issue and has now become an immobilizer Issue. https://landroverforums.com/forum/di...e2/#post731298
Old Jun 13, 2021 | 07:59 AM
  #33
roverrichard's Avatar
7th Gear
Default eka code
i have a 1999 disco 2
the engine appears to have gone into lock mode
the remote on the key will open and lock the doors
but the red alarm light on dah stays blinking fast and slow
and the hazard/ 4 ways will not stop
but the engine will spin over but not start
can any one help
i have tried the 1515 eka number
dont know the original one
Old Aug 29, 2025 | 07:10 PM
  #34
GRpufnstuf's Avatar
Red face EKA my what now?
"Originally Posted by southfloridadiscoII
Wait for 5 seconds.
start.
the system will ignore any further attempts for the next 10 minutes."
WOW, I've been beating my head against a 1999 Disco2 (north america) that won't start all day. NOTHING happened that should have caused an issue. It was cranking but would start. I was getting ready to start putting crank sensor, looking for replacement bsu, tried resetting the inertia sensor and was thinking i needed to get into the ignitoni lock/switch area to boot.
EKA 1515 seems to have sorted my issues. It did the; lock door and wait 5sec then 1 unlock, 5 lock, 1 unlock, 5 lock, then unlock and it started right up.
Now given the nature of my electrical system I can't say for sure that this was the real fix but it's certainly the only thing I tried today that seems to have had a result.
My truck will be for sale soon...
bulletsnbait
Mar 20, 2022 06:30 PM
Neil Warnes
Aug 13, 2018 12:25 PM
Jabez
May 16, 2013 06:17 AM
edwhittle
Feb 5, 2013 08:48 AM
aarongregor
Jan 21, 2013 11:39 PM
