Disco II knock.. changed everything, now what?
Old Nov 3, 2013 | 10:05 PM
jfall's Avatar
If you first start it up and there is no knock - and you need to drive it about 10 minutes
and then there is a rap, rap, rap, it could be a slipped liner.
What do you mean by blow by on #7?
You could have a bad cylinder head gasket.
Old Nov 3, 2013 | 10:08 PM
redmanxi's Avatar
When it is warm the knocking starts. There is blow by when warm. Cyclinder 7 has a misfire.
Thanks for the info.
Old Nov 4, 2013 | 01:07 PM
jfall's Avatar
Is coolant going down every week or two?
If that sound is a rap rap rap sort of tinny - then probably a liner.
If you sit in park and have it idle it raps.
If you take the RPM's up - the RAP will stop as the rings on the piston can't grab the
liner fast enough and smack it against the head.
People do pin the liner with a screw into the bottom of the liner below the travel of the piston rings.
There are write-ups on this BB.
Old Nov 5, 2013 | 08:53 AM
redmanxi's Avatar
Thanks for the info! My bro in law has a shop in Dallas and I'm just passing this info along. I really appreciate the help, it's been a learning experience for me.
Old Nov 5, 2013 | 02:39 PM
redmanxi's Avatar
Originally Posted by Spike555
You dont need to do anything other than buy a different thermostat, the colder one.
Call Trevor at Land Rover Parts and Accessories from RovahFarm and tell him you need the "colder" t-stat.
Install, problem solved.
Cost is under $50 and takes 15min.
You have a cylinder liner that is moving once warmed up, no test can find it, it is what it is, the only true fix is a new engine.
The different t-stat will keep the engine cooler so the liner wont move.
Is there anyone else that has done this?
Old Nov 5, 2013 | 02:44 PM
pinkytoe69's Avatar
Lots of people.
Get the OEM gray from rivers north though.
Old Nov 5, 2013 | 07:04 PM
jfall's Avatar
How liners fail
JE Robison Service — the blog: The last word on Land Rover liner failures - I hope!
Pinning a liner
see http://www.landroverresource.com/doc...g_V8_Liner.pdf
Old Nov 6, 2013 | 08:08 PM
redmanxi's Avatar
Default uh..
Originally Posted by pinkytoe69
Lots of people.
Old Nov 6, 2013 | 08:50 PM
pinkytoe69's Avatar
The colder (180*) thermostat
Old Nov 7, 2013 | 12:50 PM
agthird's Avatar
so its throwing a code that cylinder 7 is mis-firing? just wondering if you might be hearing an exhaust leak....
