Disco II overheat
Old Jul 8, 2011 | 02:25 PM
You never open the coolant system unless it is bone *** cold!!!!!!!!!!!!
You have truck issues, stop driving it and send me your number so we can talk before you toast the engine.
Old Jul 8, 2011 | 03:54 PM
sorusty's Avatar
Originally Posted by trey_harper
I'm having the same trouble. I have no leaks, but when I open my reservoir it fills up with fluid when the engine is hot. I haven't checked cold. Also, it heats up and the light comes on, then it cools down and goes off... really quirky
I was having the same problem and it turned out to be my thermostat. Dont buy a generic one, i made that mistake the first time, make sure it is a genuine LR part
Old Jul 11, 2011 | 03:57 PM
janderso's Avatar
5th Gear
Thank you so much for all your help. I figured out the problem myself-feel pretty dumb. It turned out to be a loose clamp on one of the two hoses that attach to the front of the manifold.
Old Nov 22, 2024 | 12:41 PM
Hixx's Avatar
Originally Posted by Disco Mike
I will be heading out of town, possibly tomorrow, for 7 to 10 days, so get back to me today.
I have a truck is overheating I had to change the thermostat and water pump and it's still overheating but when I add water it takes very little water my heater doesn't work it's possible that I switched the hoses the wrong way when I put them on the thermostat as it didn't give me directions to tell me which one went to which one
Old Nov 22, 2024 | 06:57 PM
H20nSnow's Avatar
Hi Hixx, this is a 13 year old thread. On this board you are better off starting a new thread of your own than using one so old.
It sounds like maybe you didn't properly fill/purge things. It takes a particular procedure to do that. Do you have the Rave manual? It is an essential tool.
Rando B
Jan 2, 2015 08:15 PM
velija
Feb 3, 2012 08:19 PM
BURover
Aug 24, 2010 10:17 PM
ajs1iron
Mar 8, 2007 12:22 AM
whitedisco11
Apr 27, 2006 07:42 PM
