Disco II overheating
When you pull the tstat and run it there is nothing stopping the coolant flow to allow the engine to come up to operating temps. I bet if you let it run long enough it will overheat. When you say "overheating" how are you seeing this, via the temp gauge in the instrument cluster? If so that very bad. There could be a number of reasons for the overheating, from blown head gasket allowing exhaust gas to enter the coolant to simple things like a bad coolant overflow tank cap allowing the coolant to boil and overflow to early.
