Disco II overheating
Old May 11, 2014 | 04:15 PM
NJ_Avenger's Avatar
4th Gear
Default Disco II overheating
Hey guys, I got an 02 disco with overheating problems. Pulled the t/stat and it ran fine. Just flushed everything and put the t/stat back and it's overheating again. No leaks anywhere. Brand new t/stat. Any ideas? Thanks ahead of time..
Old May 11, 2014 | 06:24 PM
jafir's Avatar
Bad new t/stat?
Old May 11, 2014 | 07:35 PM
zski128's Avatar
When you pull the tstat and run it there is nothing stopping the coolant flow to allow the engine to come up to operating temps. I bet if you let it run long enough it will overheat. When you say "overheating" how are you seeing this, via the temp gauge in the instrument cluster? If so that very bad. There could be a number of reasons for the overheating, from blown head gasket allowing exhaust gas to enter the coolant to simple things like a bad coolant overflow tank cap allowing the coolant to boil and overflow to early.
Old May 12, 2014 | 08:03 AM
drowssap's Avatar
a bad t-stat is quite common
Tom Condon
Oct 19, 2006 08:22 PM
riebs
Aug 29, 2006 03:05 PM
procurbusa
Aug 14, 2006 03:19 PM
forbin10
Dec 1, 2005 07:55 PM
bakerww
May 24, 2005 09:35 PM
