Disco II Power Steering Question
Old Oct 28, 2014 | 06:11 PM
MaineDisco2's Avatar
Default Disco II Power Steering Question
So my power steering is groaning and my fluid reservoir looks like a Jacuzzi when is running.
I'm clearly sucking air badly. Is this the pump, the steering box seals or the hoses?
I want to repair myself and need to narrow the field.
THNX
Old Oct 28, 2014 | 07:30 PM
potxoli's Avatar
The jacuzzi action is normal from all the research I've done. Mine bubbles quite bit, but does not groan.
Old Oct 28, 2014 | 07:44 PM
Two Rock's Avatar
Stupid question but is the level correct, and are there any leaks in the system? Its normal to look into the reservoir while its running and see the return fluid creating a disturbance, are u seeing bubbles?
Old Oct 28, 2014 | 10:16 PM
Oh I know it's going to circulate but its foaming like crazy with air bubbles. As near as I can tell the hoses are fine. Fluid level is full as well.
Possible issues?
Old Oct 28, 2014 | 10:28 PM
Two Rock's Avatar
Does the steering require more force than normal to turn the wheel?
Old Oct 28, 2014 | 11:28 PM
no, that is the interesting part. Turns fine. Whines like crazy when I turn. Groans the rest of the time. foamy bubbles in the reservoir
Old Oct 28, 2014 | 11:39 PM
Two Rock's Avatar
If it were my truck I would try a good used power steering pump, as hoses really can't cause this issue and neither should the box. Any good junkyards up there where life is what it should be ?
Old Oct 28, 2014 | 11:53 PM
Oh I'm sure I can find one easily enough. I'll go pull one out of a carcass somewhere. Thanks for the help.
Old Oct 29, 2014 | 12:09 AM
Colorado David's Avatar
I've gotten pretty good at changing power steering pumps. I put in two used ones before buying a new pump.
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
