Disco II slightly tilt to the right
Hi,
I'm new to this forum and have finally joined the community and purchase a 2001 Disco II SE-7 myself.
Now, after I've got the vehicle, I've noticed there's a small angle of tilt to the right and I don't know if this is the characteristic of the Disco or is something wrong with it. Can someone please help me with this problem?
Thanks,
Vernon
Thanks,
Vernon
i have a 96 and no tilt. it may that wear and tear on the vehicle tends to be more on the driver side. usually the occupied side. I don't know if there has been some type of compensatory mechinism to of set it or not. I hope others will reply. gotta love a rover. duboff
I'm sorry but that last answer you got was incorrect. Discos DO lean that way. The springs in the front end are different. They bear different load capacities to compensate for the weight difference with a driver onboard. It should ALMOST be level going down the highway. If yours DOESN'T lean, then your springs are weak.
