Disco Mike Needs Suspension Information Help
Old May 14, 2009 | 09:21 AM
Default Disco Mike Needs Suspension Information Help
Does any one own a D2 running 265/75/16's that has OME 762 rear springs? If so could you measure the height of the rear lift from the ground thru the center of the wheel to the lower wheel well molding and get back to me.
Thanks
Old May 14, 2009 | 10:18 AM
Jupiter Rover's Avatar
Not sure if this is Some of the information you needed, but I measured the Center of the Wheel to the bottom of the arch and it is 20.25".
However I have 285/75 r16 tires so I could not measure the center of the wheel to the ground because my tires are different. I do have 762 OME springs.
Old May 14, 2009 | 10:39 AM
If you get a chance could you measure from the ground to the wheel well molding, I can adjust for the 285 size tire.
Thanks
Old May 14, 2009 | 11:09 AM
Will do.
Old May 14, 2009 | 11:15 AM
There is also this site: http://www.muddyoval.com/articles/di...ing_height.htm
And this site: http://members.shaw.ca/jbarge/springinfo.html
Old May 17, 2009 | 03:14 PM
gilder's Avatar
I've got the RTE HD springs front and rear with 265/75/16 mud tires. The distance on my 2002 D2 is exactly 36 inches.
Old May 17, 2009 | 05:24 PM
AK Rover's Avatar
Why are you wanting that information Mike? Problems with SLS?
Old May 18, 2009 | 11:22 AM
AK, you know better then to ask that question, especially after our last trail run!!!
Yes, I am looking at my options.
Old May 18, 2009 | 03:24 PM
AK Rover's Avatar
Sorry, I couldn't resist
Old May 19, 2009 | 12:25 AM
Disco Fuego's Avatar
Mike,
I just put brand new BFG 265/75/16 on mine and i have the OME 762's. Mine sits at exactly 37". I have them inflated at 42 PSI. Reminds me of a question: They say max PSI is 80. What would you recommend for highway use?
Here's a picture:
