Disco Mike Needs Suspension Information Help
Old May 19, 2009 | 05:11 PM
malmberg's Avatar
Mine is sitting at 35" with the 762s.
Old May 19, 2009 | 05:20 PM
AK Rover's Avatar
Originally Posted by Disco Fuego
Mike,
I just put brand new BFG 265/75/16 on mine and i have the OME 762's. Mine sits at exactly 37". I have them inflated at 42 PSI. Reminds me of a question: They say max PSI is 80. What would you recommend for highway use?
Here's a picture:
It looks like you have some rust going on on the undercarriage and suspension. For tire pressure, you'll have to play around a little and find what you're comfortable with. I wouldn't run them at 80 for sure. Full size, 1 tons with a full load run 80 psi. I wouldn't go above 60 personally, and 50 would probably be a good comprise of ride comfort and tire wear.
My new tires are C load range instead of E like yours so my max is 50 psi. I run them at 40 front/45 rear on the highway and it seems like a good combination for my truck/tire setup.
Old May 19, 2009 | 05:33 PM
Thanks guys, I have what I need.
By the way, I run 40 pounds all the way around for both ride and better tread wear.
Old May 19, 2009 | 05:37 PM
AK Rover's Avatar
Wouldn't 40 psi on his 80 pound tires still put a lot of wear on the tires, particularly the outside edge of the tread?
Old May 19, 2009 | 09:01 PM
Disco Fuego's Avatar
Thanks AK. Will load them up to 60 and see want it does... Any recommendations on the rust issue?
Old May 19, 2009 | 09:27 PM
AK Rover's Avatar
I'm guessing the truck in the picture was not originally a CA truck. I would get some rustoleum or something like that and paint all of the rusted areas to prevent or slow the spread. Get the rustoleum that turn rust to primer. It would be time consuming but sure beats the rust eating anything important.
Old May 20, 2009 | 01:02 AM
You're correct. It's a NH car. Been debating on what to do with the rust. It's not a big deal, but I would like to stop it from getting worse...
vandal996
Aug 28, 2010 12:12 PM
discomedic4
Jun 8, 2010 04:08 PM
afphinfan
Dec 5, 2007 08:45 AM
jeepetr
Feb 10, 2006 09:33 PM
