Disco Running Rough When Idling
Old Jun 24, 2009 | 12:09 PM
ezioc's Avatar
Default Disco Running Rough When Idling
Hopefully someone could help on this.
I have a Discovery 2 with about 93k miles. The check engine light kept coming on. When I brought it to the dealer, they indicated that the the Mass Airflow Meter was bad. I was able to get another Meter and installed it.
The check engine light still comes on. Now it runs a little rough when idling. While driving it seems fine.
Took it to my local mechanic. He indicated that it looked like one of the oxygen sensors may not be working. He said the engine was running lean.
I took it to the Land Rover dealer to get codes pulled. the indicated that the Mass Airflow Meter and both oxygen sensors were showing up and bad. They indicated that the Mass Airflow Meter could be bad and affecting the oxygen sensors. Could the new Meter also be bad? Could the oxygen sensors be affecting the airflow meter. I still have the old Airflow meter. Could that one still be good.
I am getting confused. If anyone could shed some light on this, it would be greatly appreciated.
I don't mind getting the work done, I just don't want to have to do unnecessary work.
Thanks so much.
Old Jun 24, 2009 | 01:07 PM
So start all over, go get your codes read and stop throwing parts at your truck till you really know what is wrong with it.
Was the MAF new or used??
Get us the 4 digit fault codes and let us help you.
Old Jun 24, 2009 | 01:57 PM
tornado_735's Avatar
Check the Idle Air Control
Old Jun 24, 2009 | 02:07 PM
ezioc's Avatar
OK.
The Mass Airflow meter was used.
Here are the codes (P0130, P0150, P1129, P0174, P0171)
Thanks for the hlep
Old Jun 24, 2009 | 02:13 PM
P0130 - Oxygen Sensor Cycle Fault Bank A (Cylinders 1,3,5,7) before the Cat
P0150 - Oxygen Sensor Cycle Fault Bank B (Cylinders 2,4,6,8) Before the Cat
Closest I could get on the P1129 was:
P1130 Oxygen Sensor Fuel Trim at Limit Bank A Before the cat
P0174 - Oxygen Sensor System Too Lean Fault Bank B
P0171 - Oxygen Sensor System Too Lean Fault Bank A
Your front oxygen sensors are toast, and leaning you out.
Old Jun 24, 2009 | 03:21 PM
ezioc's Avatar
Thanks so much.
dillhole
Feb 20, 2020 02:30 PM
EVN137
May 25, 2011 11:03 AM
alemurill
Dec 28, 2008 08:46 PM
eriqcharlz
Jul 3, 2007 09:30 AM
EVN137
May 30, 2007 07:24 PM
