Disco Subwoofer Replacement Speaker Question
Old Apr 2, 2009 | 07:23 AM
mellyagaunce's Avatar
Default Disco Subwoofer Replacement Speaker Question
Does anyone know if a shallow mount 6.5'' speaker will work as replacement speakers for the sub without having to dig a hole in the back of the box for the magnet to fit in?
Here are the speakers I was looking at
http://www.electrawarehouse.com/prod...icker+08CVT654
They are 4 ohm, single voice, 6.5'' shallow mount speakers.
Let me know! Thanks
Old Apr 2, 2009 | 04:32 PM
Frank4's Avatar
I just switched mine with Pioneer TS-A1702C. It is separate 2-way set, I just didn't bother with the tweeters. It was a tight fit but I managed to get the door unit back together. They sound pretty good. This set is not a shallow mount set so I don't see any problem with the set you are looking at.
Old Apr 2, 2009 | 09:34 PM
Dream Theater's Avatar
I currently have mine taken out of the back door as I had to get to the tail door actuator to replace the lock. Just got the part in today and it will be raining until Saturday, so if you need me to measure something specifically, let me know exactly what you need and I will measure it. I plan on putting the actuatir in on Saturday when it finally stops raining, so let me know by then.
Old Apr 2, 2009 | 10:13 PM
grussell's Avatar
They should fit if you have the sub woofer housing mounted on your rear door. The 6.5 is the right diameter.
JamesDisco97
Oct 6, 2011 04:39 AM
DayPhan
Sep 4, 2011 01:08 PM
Classklown90
Jan 17, 2010 09:57 PM
Robwsup
Jan 16, 2010 10:59 PM
slamwhit
Oct 1, 2005 02:34 PM
