Disco tdi won't start- immobilser?
Old Dec 2, 2004 | 08:15 PM
RICHARD1958's Avatar
Default Disco tdi won't start- immobilser?
help
I turn the key , get all the lights but she won't turn over - or do anything at all on the key
help , cannot get her to start!!
Old Dec 3, 2004 | 04:21 PM
Takeo's Avatar
Default RE: Disco tdi won't start- immobilser?
Hi !
Of course, it might be your immobilizer at fault, if installed. Look in owner's manual.
OR it might be anything plain electric between your contact lock and starter motor, or your computer playing up.
Not easy to diagnose at a distance...
Best regards,
Takeo.
http://www.landroverclub.net
Old Dec 6, 2004 | 04:21 PM
Lighting90's Avatar
See my reply in the techincal section for you, let us know how you get on
Old Dec 27, 2004 | 12:32 PM
BrianH's Avatar
Did this fault appear all of a sudden or have you had problems in the past? I found that the starter motor on my Discovery would sometimes go faulty after a long journey (after it's really warmed up) and if I stopped for Diesel or to pop in a shop or whatever it wouldn't turn over. At first I thought I had an immobiliser fault but it turned out to be the starter motor. If I left the vehicle to cool down it would normally start fine, or giving the starter motor a swift tap with a hammer could normally convince it to start. After that it would be fine for a couple of weeks, maybe over a month before it'd do it again.
Eventually the problem decided to get worse and one day it refused to start no matter whether it was hot, cold or whether I beat **** out of the starter motor. A replacement starter cured the problem.
Hope this helps
Brian
dirkha
Feb 10, 2021 06:44 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
LandRoverE6
May 25, 2013 02:17 AM
Budvar
Dec 20, 2007 06:12 PM
