Disco Transmission
Old Jul 23, 2013 | 10:49 AM
caymandrew's Avatar
Default Disco Transmission
Guys,
One thing I have noticed here is a lack of transmission posts? Aside from the driveshaft puncture, I've not really seen a lot of problems. Are they pretty reliable?
Old Jul 23, 2013 | 10:52 AM
drowssap's Avatar
like everything else Land Rover most of it problems are electrical
Old Jul 23, 2013 | 10:55 AM
But if well serviced, every 20,000 to 25,000 miles, they will last a long time.
Old Jul 23, 2013 | 11:01 AM
antichrist's Avatar
The automatics don't like water however, as in submerged. That will pretty much trash them.
Old Jul 23, 2013 | 11:18 AM
True, but if your vent tube is properly attached and no seals leaking you should be OK, just like anyone elses tranny. I have had mine under water many time and not had a problem, same holds true for the diffs and t/case.
Old Jul 23, 2013 | 12:59 PM
Madlands's Avatar
Don't mean to hijack the thread, but it looked like my question may fit. Has anyone used the White Shepherd stuff on their transmission? I recently noticed I have a transmission leak coming from between the t-case and transmission. It can sit for a week and not drip a drop on the ground but I get a few drops on the cross member bar when I've driven it. I don't have the time or funds to work on a transmission right now, so I was hoping to hear some good results.
Old Jul 23, 2013 | 01:17 PM
jfall's Avatar
Few drops? That is not a leak in my book
Old Jul 23, 2013 | 01:23 PM
Madlands's Avatar
Haha I don't really consider it a leak as much as an annoyance. I'm fine with engine leaks/drips, but it takes a little more effort topping off the transmission. Plus I would like to try and keep the drops from turning into bigger drops as long as I can.
Old Jul 23, 2013 | 02:15 PM
antichrist's Avatar
Not really. Diffs and transfer case are easily drained and refilled, nothing water will hurt provided it's removed in a timely manner.
Old Jul 23, 2013 | 02:40 PM
FlyingZebra34's Avatar
By posting in this thread you just jinxed your transmission .
