disco turns off and hazard lights on
Old Jan 11, 2014 | 06:56 PM
Roustabout's Avatar
Engine shutting down and hazard lights flashing - sounds like the inertia switch is tripping.
Old Jan 11, 2014 | 07:39 PM
Jared9220's Avatar
Have you done any repairs on the truck recently that would have required you to take anything apart?
Check all of your ground cables.
Old Jan 11, 2014 | 09:21 PM
marizcal's Avatar
The last thing I remove it was the throtle body.. to clean it and to fix a water leake... justa that.... but the problem is not new,.. it has more than a year... it is until now that is more frecuent.... and for the ground points..I just start checking that... cleaning all that is under the hood and engine....
Today I has to disconnect the battery for a while, to reset the fault.. hazard lights flashing...did not respond with the remote control...
What is the inertia switch?????
And for the p0140 code... o2 sensor ... today I disconnect the sensor and in the female one.. the one to the harness.. there is a dirty terminal..looks with some rust... I going to clean it an see if this fix that code....
thanks for read.. and continue cleaning ground points... any other idea to check ???
Old Jan 12, 2014 | 07:40 AM
Here is pix and location of inertia, press down in center of top to firmly reset. The function of the inertia switch is to shut down the fuel system in a crash and unlock the doors so people who come to help can drag you out of the vehicle.
File Type: pdf
Old Jan 12, 2014 | 08:39 AM
marizcal's Avatar
ok.ok... I got it... but is a but... this switch cut the gas... and my disco turns on again, in Neutral or Park... just keep the flashing hazard on... fast and low....
Old Jan 12, 2014 | 10:40 PM
marizcal's Avatar
hey I found this thread..... https://landroverforums.com/forum/di...h-49945/page2/
it has the same symptoms like mine.,,, and the responsable is tha Alarm ECU or Alarm Control Unit.... I am thinking in replace this module, but some one knows if it needs to be programmed ??? or just disconnect and connect...???
Thanks...
Old Jan 13, 2014 | 08:32 PM
marizcal's Avatar
never mind... I read better and that module is for Disco I ..... so bad I was thinking that I found the solution....
an update... I finished checking all ground points and all are ok... I cleaned anyway one by one....
any more that can be checked....
thanks...to all
Old Jan 28, 2014 | 07:54 PM
marizcal's Avatar
Default inertia switch...
hi, I back again... Another update, to comment what I do to my disco...
I took look to the inertia switch, and I found that it doesn't have the rubber cap.. so I disconnect it and check it... it looks so dirty and with rust inside.. so, I decide is time to change it......
I don't know if this was causing the problem.... take a look to the pic... but it is suspect due to the bad shape of the inner parts.... so I done this change 2 weeks ago.. aprox... and the truck worked good until now.....
Maybe, due to the rust and dirty, it was working wrong or giving a false inidcation to the ECU/BCU...maybe....or have some humidity that causing this malfunction ....
Thanks to all and just to letting know what was or probably was the problem... hope to be helpful for someone else...
see you.
today has been almost 3 months..
no more problems with the hazard lights and/or engine dies...
so the problem was THE INERTIA SWITCH .....
Last edited by marizcal; Apr 26, 2014 at 08:34 PM. Reason: confirm what was the problem...
Old Sep 18, 2016 | 09:21 PM
marizcal's Avatar
ok guys and gals.. just to confirm.. it was the inertia switch.. since I changed.. no more engine off and hazard lights on... It is been more than 2 years.. nice..
Old Sep 20, 2016 | 02:34 PM
dgi 07's Avatar
Can someone award this man for coming back almost 2 years later to confirm his problem. You sir, should be team player of the year. !
J dog
Feb 10, 2021 10:14 AM
Lord Wert
Jul 4, 2013 07:52 AM
me 2
Jun 17, 2012 07:24 PM
AmyRover
Engine & Internal
Dec 26, 2009 06:32 PM
AmyRover
Dec 13, 2009 01:03 PM
