disco will not go into gear
Old Mar 6, 2007 | 12:52 AM
mdl4usc's Avatar
5th Gear
Default disco will not go into gear
my1999 Disco will not go into gear, it just goes into neutal when put into drive or reverse
Old Mar 6, 2007 | 09:56 AM
Default RE: disco will not go into gear
How many miles on the truck, did this happen all at once, when was the fluid last checked and changed? Do you have any warning lights showing up on the dash?
Mike
Old Mar 6, 2007 | 03:27 PM
ChuckD's Avatar
Can you make the truck move by putting transmission in 1st gear and then going up through the gears using the shifter? That's the way mine worked after i ruined (spun out) the sprag clutches by accidentally towing the Disco with the xfer case in low range.
ChuckD
GodSavetheQueen
Aug 19, 2013 07:01 AM
green-lantern
May 16, 2013 01:41 PM
Summit rover
Apr 11, 2012 06:54 PM
kerryslemon
Oct 21, 2011 04:45 AM
jmccollister
Oct 11, 2009 06:01 PM
