Disco2: weird dome light issue
Old Dec 12, 2018 | 08:48 PM
ReconDoc83's Avatar
Default Disco2: weird dome light issue
So when you want the “auto-dome” lights to come on when doors are opened; and fade out once doors are closed, the dome light armature needs to been in the CENTER position....right? Right...
So tonight for some dumbass reason my dome lights stopped coming on when doors are opened; stopped fading out when doors are closed; stopped going out after 15 seconds when truck is locked....
front cockpit light works in ON position.
rear cargo light works in ON position.
front cockpit light works in center position once ignition is keyed.
rear cargo light works in center position once ignition is keyed.
center passenger compartment light has gone bad / out (today / tonight maybe); need replaced...is this the problem?
OR is there some other gremlin in the system / ghost in the machine I am not aware of?
thanks
Doc
Old Dec 12, 2018 | 10:51 PM
Sandman614's Avatar
thanks
Doc
The first thing that comes to mind is our leaky sunroofs and that electricity places funny games when wet.
Old Dec 12, 2018 | 11:41 PM
ReconDoc83's Avatar
nah; no rain here of late....and I (fortunately) haven’t been a victim of the leaking roof (knock on wood).
Doc
Old Dec 13, 2018 | 05:19 AM
JUKE179r's Avatar
a 19 +/- year old vehicle might have corrosion build up from years of moisture.
pull the light assembly and check the electrical contacts for corrosion.
Old Dec 13, 2018 | 09:56 AM
Ben Matheson's Avatar
Mine act funny if I've left the doors open long enough that they automatically turn off. They went back to normal after driving the vehicle and cycling the door locks with the fob
Old Dec 13, 2018 | 10:38 AM
zuke's Avatar
All of mine have a dome light that does not come on after the rear door has been opened. Next time it comes on. WTF
Old Dec 16, 2018 | 12:20 AM
ReconDoc83's Avatar
Where is the door jam button that shuts the interior lights off....like every other vehicle ever built throughout history?
I have not seen a single door jam button.....is it an electrical circuit inside the driver door master actuator?
Doc
Old Dec 16, 2018 | 04:09 PM
ReconDoc83's Avatar
Still can’t find the door jam switches that activate the dome lights when a door is opened...
was looking in in the overhead area of the front dome light...I found the single lead black wire connected as it should be; but I found the connector in the picture dangling loose anyone know where it goes? Maybe a spare if I had a sun roof?
Old Dec 17, 2018 | 09:46 AM
Motorhead1's Avatar
On mine, the dome lights will automatically shut off if you leave a door open for x amount of time, it's a battery drain safety feature. Mine will not start working again (auto feature) until I cycle the ignition switch. The auto dome light function is tied into the ignition somehow....I'm sure it is explained in the RAVE. Ohh, and their is NO door switches.
Old Dec 17, 2018 | 09:56 AM
Yep exactly what mine does
