DiscoII Tire size upgrade
Old Mar 1, 2012 | 04:31 PM
Maurice Carter's Avatar
4th Gear
Default DiscoII Tire size upgrade
Need to know if I use a larger tire size would thay be ok or not. I was told I can use a 245/75/16 instead of the OEM size of 255/65/16. Need to know because of clearence and/or diff gear problems ect. thanks
Old Mar 1, 2012 | 05:14 PM
You will be fine with the stock suspension, but no larger till you go for a lift.
Old Mar 2, 2012 | 02:26 PM
Big Jim Swade's Avatar
You can also go with a 255/70-16 if you don't want to go to a skinnier tire.
Maurice Carter
Mar 5, 2012 11:04 AM
Outback Jim
Dec 5, 2011 06:55 PM
DV57
May 28, 2007 09:31 AM
Leo
Tires
Oct 9, 2006 06:25 PM
LR3invancouver
Apr 14, 2005 07:25 PM
