Disconnected brake line
Well that is problem - I suggest you get a Land Rover capable code reader and pull codes, and pull the tire check the caliper pads and rotor on the one that is disconnected my bet is it shot. This is a giant red flag - you may have bought a truck in serious need of a lot of repairs,beyond brakes.
Are we talking brake line or ABS sensor wire? The two are different levels of seriousness.
Sounds like it's the wire, if it is then it's probably just a bad sensor that you can replace.
If it is a brake line, I'd be a lot more worried about driving it around. You'll have to diagnose the caliper and ABS block to see which isn't working/seized
That is seriously bad - that big block of metal is your ABS modulator. I bet is is you are running on 3 brakes and the right rear is dead, this is better than a front brake but still very bad.
I suggest you check you dash lights when you turn the ignition key on I suspect some are not illuminating that should, the image below will show you what will light when you turn the key on.
To me this is huge warning flag about the rest of truck - replacing a disk brake system is not hugely expensive :
If a guy will not spend call it 400.00 on brakes what else did he not fix, wish luck on this.
- Caliper 140.00
- Rotor if shot 120.00
- Pads 80.00 (set of 4)
- Bleed if you can not get it right 40.00
