Discovery 2 - 2004 - No Start
Old Oct 4, 2021 | 10:31 AM
mollusc's Avatar
It's just a switch. You should be able to connect the wires together to complete the circuit to bypass it.
Old Oct 4, 2021 | 12:52 PM
Rovered's Avatar
8th Gear
Got it, I will give that a try tonight. Does anyone have any thoughts on the beeping and instrument panel lights when turning the engine over? Maybe it represents some kind of fault?
Old Oct 4, 2021 | 07:03 PM
Rovered's Avatar
8th Gear
Just tried jumping the inertia sensor, still no change. Also tried swapping some fuses and relays around for the related systems. Officially stumped. I didn't change any parts during the few hours I had the fuel tank out, I don't understand why this would cause the injectors to stop firing. Unless this is another example of my car's impeccable timing with things breaking
Old Oct 4, 2021 | 07:27 PM
Extinct's Avatar
Squirt some fuel in the intake and crank it.
Old Oct 5, 2021 | 08:48 AM
Rovered's Avatar
8th Gear
Quick update from last night, tried spraying fuel into intake after MAF sensor per Extinct's recommendation, this allowed it to run but only for a couple seconds until it burned off the fuel in the intake. The injectors still do not seem to want to activate. It is worth mentioning that a local Land Rover shop installed a used ECU as part of their effort to eliminate a P1171 code (which returned a week later). This ECU change was made two weeks before this problem started. Don't know if this could have something to do with it, I know cars can be fussy sometimes about having different ECUs fitted.
Old Oct 5, 2021 | 02:10 PM
Richard Gallant's Avatar
Dead fuel pump relay ?
Old Oct 5, 2021 | 02:19 PM
Rovered's Avatar
8th Gear
Richard, I wish. I swapped some relays and fuses around the other night, to no avail. I was also able to slightly depress the Schrader-like valve on the fuel rail and found that fuel is making its way to the rail and is getting flow/pressure when the engine is cranking. Would it be possible for the injectors to refuse to fire is there isn't enough fuel pressure?
Old Oct 5, 2021 | 02:41 PM
Hmmm I will have to look but I thought there was troubleshooting diagram on this.
Low pressure is a possibility, that be checked that Schrader Valve. But it sounds like it is fueling related, could be the pump is going.
Old Oct 5, 2021 | 06:25 PM
Extinct's Avatar
If you have pressure at the schrader valve then not the fuel pump. Most likely a CPS, you need a spare anyway so buy a spare and swap it. If it solves your problem, done. If not, you have a spare. I like to test with a known good one, so hopefully there is a breaker near you where you can get one off a running truck super cheap.
Discov8i
Aug 25, 2013 07:25 AM
bilmgl
Oct 2, 2011 02:56 PM
timothyfuqua
May 30, 2009 08:35 PM
dombam
Nov 3, 2008 01:54 PM
2000 Disco 2 SD7
Aug 20, 2008 12:37 PM
