Discovery 2 Low starter voltage
Old Apr 16, 2011 | 08:25 PM
rhyslegge's Avatar
Default Discovery 2 Low starter voltage
Hey all, been a while since my last post. I have a problem, 2000 Disco 2 with low starter voltage?! The starter will not turn and and solenoid won't make any sound at all. I checked the battery voltage and it is 11.5 volts, during starter energizing I only have 9.1v at the starter positive post! I hooked up the ETHOS and an engine immobilizer code popped up, so I reset is and followed onscreen instructions, code did not latch and problem persists. I swapped out the starter relay with a known good and no change. Any advise would be appreciated, thanks!
Old Apr 16, 2011 | 09:07 PM
mwindth's Avatar
I guessing bad battery...should be 12.5/14.5 volts...how old is it?
Old Apr 17, 2011 | 06:29 AM
rhyslegge's Avatar
You think it could be that simple? I assumed that even with 11 volts id at least get a hint of starter engagement. I guess that would be a good place to start, the battery is at least 5 years old. I guess I was over-analyzing!
Old Apr 17, 2011 | 07:25 AM
Bundu's Avatar
Banned
Engine earth strap OK?
Livingintheskies
Apr 9, 2018 11:17 PM
redwhitekat
Jun 17, 2013 06:36 PM
Rover De Land
Aug 21, 2012 05:29 AM
kae
Aug 18, 2009 11:05 AM
