Discovery 2 Secondary air pump
Hey guys, I just registered but have picked up dozens of helpful tips on here since buying my discovery 2. I’m wondering if there’s a simple way to disable this loud a$$ secondary air pump without going through the lengthy procedure to do it without throwing a code. I don’t care about throwing a code as long as it doesn’t cause actual issues with the engine. The previous owner cut out the cats and made it straight pipes anyway, so it’s always going to have the emissions code. Every light that can be on is illuminated on the dash already, so really not a big deal! It’s a 20 miles or less vehicle for me that we take driving around pastures and such, and I just want the jet engine noise to stop when I start the vehicle! Dedicated fuse I can pull maybe? Disconnect wiring so it doesn’t run? Hoping there’s an easy fix given I don’t care about the codes or check engine.
#1. That picture is a whole situation... hahaha
#2. If you really don't care about codes and warning lamps, I think you can just unplug the SAI pump (pass side, behind battery near fusebox next to firewall). Proper way is to remove the system, pipes, cap the pipes on the heads or use non SAI heads, and swap the ECU, then blah blah...
I had a Disco with a dead SAI pump once, and my recollection is that car started and ran just fine, but with check engine light. I remember being really annoyed paying alot of money at the time to fix something that did nothing other than eliminate a warning lamp (and emissions of course). So I would thus speculate, if you just unplug the SAI pump it would do the same thing as if you had a bad SAI pump.
BTW They're not that loud when they are fully functional btw... always a bit louder on the 4.6 (2003-2004 like yours), but I've always thought it was a bit of a cool Disco noise to hear.
Thanks,
Gregg
Uhhh, yeah. With that out of the way, the pump may be screaming because its intake filter has a problem, Clogged, ruined, broken apart and being sucked into the fan, etc. Or maybe the pump just needs lubricating. If dash lights are truly not an issue then you can certainly just pull the plug out. Ok, I've said enough, I'm already feeling greasy.
I had a loud SAI pump. Got the ebay special from a low mileage junker and did the Juke Filter Mod. It worked like a charm and has been totally operational.
There is also a write up to replace all the stock tubing with temp rated hoses and piping all available from home depot. I have not done that.
There is also the bypass/delete mod. If I recall correctly you can flash the ECU to change the SAI setting to identify that it is not present after plugging the holes and deleting tue components.
I like Juke’s filter mod. It’s makes servicing the filter much easier and you can get the K&N Filter shipped to any auto store within a couple days.
Let me see if I can find the write up and part number for you. Search in google Juke SAI Filter Land Rover Forums and it should pop up. There are many available pumps on ebay as well.
EDIT: Glorious photo my guy. That def a vibe.
jastutte (06-30-2023)
