Service Engine Soon - Code P1412
Old Jun 24, 2006 | 12:16 AM
Different Drummer's Avatar
Default Service Engine Soon - Code P1412
My service engine soon light came on yesterday. Auto Zone read the code for me and it's P1412 Aux Emmission Controls. I was told that it could be anything from the gas cap to a vacuum leak somewhere. He reset it so the light is off now, so I'm thinking I will let it go and see if it happens again before I do anything further. Does that sound reasonable, or should I be taking it in to have it checked out?
BTW, I think I'm going to buy a code reader.
Old Jun 24, 2006 | 01:05 AM
Brad S1's Avatar
Default RE: Service Engine Soon - Code P1412
I'd wait until it comes back on, sounds like something like an o2 senor fault... then again, I still dont own a land rover
Old Jun 24, 2006 | 12:16 PM
I can't remember what that code is for, the good news is that it didn't come back, yet. Some faults that trigger the check engine light are because the ECU sees a quick qlitch that then goes away, that may be what you have experienced.
Mike
Old Jun 25, 2006 | 12:51 PM
Landzu's Avatar
Code is : Secondary air system fault bank 1 Drive cycle D: Signal implausible.
Some of the things that can cause this. You may need a service manual.
Connector : C0879 ,C0636, C0572, C0641, C0563.
Fuse #37 (30amp)
Secondary air pump.
Secondary air valve.
I would get some dielectric grease and put it in all
the electric connectors.
Mike
Old Jun 25, 2006 | 03:35 PM
Wow, thanks for all that info. I'll try to find a cheap service manual on Ebay. I'll let you guys know how everything goes.
randrews
Nov 18, 2023 02:26 PM
Torancis_LR
Sep 27, 2015 01:23 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
And4848
Aug 14, 2008 08:53 AM
nicknick
Jan 4, 2008 03:24 PM
