Discovery Crank Seal
Old Oct 3, 2011 | 07:02 PM
boris_gti's Avatar
Here is the picture and drawing of the tool as some of you wanted me to post.
Tool works like a champ. Took me 2 minutes to install it and 5 seconds to get the nut loose.
Use M8X50 bolts to bolt the tool on.
Easiest task so far in my "little project".
Cheers and thanks!
Attached Thumbnails Discovery Crank Seal-rover_tool_1.jpg   Discovery Crank Seal-rover_tool_2.jpg   Discovery Crank Seal-rover_tool_3.jpg
File Type: pdf
Old May 6, 2012 | 07:08 PM
oldcarguy's Avatar
4wd High
Default Replaced crank seal
Boris used your spec. To make the tool and made it piece of cake to change the seal thanks.
Old Aug 27, 2012 | 01:01 PM
Alan Phillips's Avatar
Looking at the RAVE, it says the crankshaft pulley bolt needs to be tightened to 200 Ft-lbs. If I were to loosen the bolt using the starter motor, how do I go about keeping the engine from turning when I go to tighten? Or is that a non-issue?
Old Aug 27, 2012 | 02:06 PM
drowssap's Avatar
if you read my post above you just find a different spot to catch the belt on.
you can actually leave the whole setup together, when you take it off.
Then its ready to go back on.
Willie 00D2
Nov 6, 2017 03:16 AM
outdoor7or24
May 21, 2012 08:34 AM
yloDiscoII
Feb 10, 2010 10:03 PM
djmik2000
Jan 28, 2009 03:58 PM
modelwerks
Oct 3, 2005 09:29 PM
