Discovery II Transmission/Shifting Problem
Old Jan 18, 2014 | 08:21 PM
djkm473's Avatar
5th Gear
Default Discovery II Transmission/Shifting Problem
Need help!! Having issues with 2003 Discovery II no modifications. After driving and vehicle placed into park, it will not go back into reverse or drive. Have to wait approximately 15-20 minutes and then it will work again. Shifts fine and runs fine when works, just have to wait before retrying. Recently changed xyz switch, transmission fluid and filter but still having same issue. Ideas?
Old Jan 19, 2014 | 12:59 AM
DiscoBeau's Avatar
See if this works before you start tearing apart your center console. Hope it helps
Old Jan 20, 2014 | 05:11 PM
djkm473's Avatar
5th Gear
the best zf4hp22/24 valve body breakdown ever
ZF 4HP22E Valve Body Rebuild
Ynot
Nov 16, 2021 10:15 PM
tbendekovits
Feb 28, 2014 10:52 AM
djkm473
Feb 1, 2014 11:12 PM
ios1000
Jan 28, 2008 08:26 AM
Tanrover
Dec 6, 2006 01:15 AM
